Hello everyone,
Apologies for me being new to the community and starting to ask questions but I am in a tough spot and I need some help.
I own a Hyundai Santa Fe 2.0 CRDi 125 hp 4WD Facelift, manual transmission, 2004 make (2005 reg) for about a year now.
After I bought the car it went through initial servicing (oil, pulleys, belts, brake fluid, brake pads, thermostat etc..) and after a couple hundred km 3 of the injectors had to be serviced. After all of the this the car was running OK and the oil level stayed the same for about 3 thousand km (5W40 Titan was used).
After that I had a 1k km trip on which I pushed the car hard - basically the whole trip was over/around 3300 rpm on 5th. After the trip I noticed that there was a substantial part of the oil missing. I had to add about 1.3 liters (5W40 Total was used to top up). The oil level notification on the dashboard did not come on during or after the trip. I know these hold 5.9l of oil but still 1.3l down is a lot.
After this trip I started topping up around 300ml for every 1k km.
I started worrying that the turbo is bad and that I might have run away diesel and because of that I went to two shops to check it and they stated that the turbo is OK. Meaning the oil consumption was caused by blowby and best case scenario is piston rings change.
In the meantime the flywheel has started to sound louder - before that it was only a slight play in the clutch pedal when held in the middle of its way.
Basically the thing is that I cannot sell the car at this state - at least not for adequate money. I have invested a lot in this car - 5 new tires that have less than 5k km and other stuff.
I am not sure if it makes sense to repair it - when the engine is pulled apart we might find that basically the cylinder walls are no good (or pistons) and a whole new block (better yet an engine) is needed which means a lot of money.
I am trying to lift my spirits up and to think that if I decide to go with the repair (flywheel, clutch, piston rings and etc..) I can at least improve the car.
Meaning maybe I can use different parts to at least make it a little bit quicker since these 125hp for this big chassis are not that much. Basically to pay for something more than just a repair and justify the money that will be spent. Make not mistake I do not have cash lying around for such things but I need a car for my family.
Sorry for the long explanation but I wanted to describe my situation the best possible way.
Basically my questions:
- is it worth to repair it
- if I decide to repair it is there a possibility to use different parts in order to improve the performance of the vehicle
I do not want to sell it to some poor guy that will have to deal with this, I cannot conceal it - my conscious won't let me do it.
Overall I like the car, I like the ride, I like the space, I like the km/l and it is the first car I have bough myself.
Thank you in advance and I apologies for the long post.
