Hi all,
I have a 2006 Santa Fe Diesel seven seater.
When in 2nd and 3rd gears, travelling around 30 to 40mph, there is a rattle like noise coming from engine-- tic tic tic almost like a tapit noise . Engine is very noisy in these low gears, then when car is in 5.th gear there is no rattling noise at all.
What could be causing this . Is it a problem in the engine or with the gear box?
Thanks all.
Dual mass flywheel perhaps? Does the rattle change or go away if you press the clutch?
Hi all,
Thanks all.
Same with my car. I hear the rattling sound at 2000 rpm or higher. Pls help....
I posted this somewhere else but a ticking engine noise could, almost, be anything. Watch this video, it probably isn't this and the guy does it on a BMW engine but if you can wade through his waffle he does say it applies to any vehicle with hydraulic tappets. I have no idea whether the SF has hydraulics or not but it's so simple it's worth a punt
