Hello, im hoping I am posting in the correct area. Im trying to run a power wire for an Amplifier. I seem to find no easy way to run this.... I believe there is a metal plate to the right of the brake booster I can drill through...but cant get off. (picture below) Any suggestions? And if the plate is a good choice, Whats behind it? or diagram....cant find one with this plate. :confused:
Look under the steering wheel. Pull carpet back and you will see the grommet for the steering column, punch a hole through that and you are in the engine bay
