1 - 20 of 228 Posts
My 2011 Elantra has a slightly rough idle at stop lights. It doesn't happen ever time, and some people probably wouldn't even notice it, but at every few/several stops it idles a bit rough. When I recently had it in to Hyundai service for the ECM update, I asked them to take a look at it. Of couse, they couldn't replicate it at the time, so they couldn't do anything to address it directly. The service manager asked if it happens when the A/C is on or off. While I didn't know the answer at the time, it seems to happen with it both on or off. He did say that the ECM update may address/fix the issue, but unfortunately it didn't. While it's not a big problem, it's a minor annoyance I'd like to get fixed (as I need to enjoy my ride at all times ^_^ ).
Anybody else notice this with their car and, if so, have you done anything about it? Any other suggestions are welcomed - especially from those who understand what causes the car to idle like that.
Retired Staff
Mine too, happens when the ac is on or off intermittently at stoplights I haven't bothered to take it in yet since I dont want my car to end up as a testbed since this is a very minor problem. It started doing it less when I switched to synthetic oil but for now my solution is to drop the car into N at a light. I'm thinking there may be a bad iacv, or maf, also possibly a motor mount or a minor vacuum issue.
I've had a slight noise also that doesn't happen all the time. Someone on here mentioned that the Oil Control Valve is loud on these motors and that might be the culprit. I've only had mine for 3 1/2 weeks and have not taken it back in for the ECM update. Did you notice a difference in the way the car shifts after the ECM update?
I too just had my 11 limited in the service bay for the excat same issue. Odd thing was there was a GLS there for the excat same thing. I spoke to the tech and he made a report on it and hopefully if more would take them in for the issue Hyundai will look deeper into it cause, even the mechanic told me it shouldnt do the rough idle thing. He told me it seemed as if the idle control doesnt account for the a\c sometimes.
So I would recommend that anyone that has this issue take it in so the paper trails start and Hyundai sees there might be a small issue here that justs needs a tweak.
I only notice the issue with the A/C running at a stop light. Sometimes its not as noticeable than other times
QUOTE (NPMountaineer @ Apr 29 2011, 11:31 AM) index.php?act=findpost&pid=437750
Yes, it reacts instantly now, rather than having a 1/2 second lag when you initially "step on the gas." So it's much more responsive now. Haven't noticed any real differnce in how the transmission shifts once "at speed" though. Then again, I never noticed any issue as far as that's concerned. If your car is included in the ECM Update TSB Campaign production date range, I would suggest getting it done.
Retired Staff
ponieus Interesting I need to run to dealer tomorrow morning for touchup paint, will stop by the service desk and ask if they have seen this much yet.
I've noticed an occasional shaking at idle too... more than I would expect from a small 4-banger. I suspect it's triggered by the A/C cycling on and off, but cannot say for sure.
PS: Someguy, I haven't noticed any difference since switching to synthetic.. nor would I expect any.
QUOTE (ImKramer @ Apr 29 2011, 11:01 AM) index.php?act=findpost&pid=437734
i can honestly say that while i am stopped at the lights, if i dont have my fan on, my car is so quiet that it feels like its not running :grin:
Retired Staff
QUOTE (Don67 @ Apr 29 2011, 02:09 PM) index.php?act=findpost&pid=437827
Yeah the less shaking since switching to synthetic thing is possibly all in my head
Just got back from an errand, and there is definitely something odd going on. Sometimes the steering wheel is visibly shaking at idle, even with the A/C off. But other times it runs smoothly even with the A/C on.
I'm a bit surprised by some of the comments above about people being fooled into the thinking the car is turned off. My Elantra has never idled that smoothly... the seatback and floorpan are constantly throbbing, as if to remind me that this is no Santa Fe. Maybe that ECM update will help.
I have noticed this rough idle too. I thought maybe it was the A/C, but it also does it with it off. I was thinking about bringing it in for this issue. It seems that the RPMs drop really low and that is when I notice it. I am glad I am not the only one to notice this.
How do I know if I need the ECM update?
A couple of questions for the people describing the the rough idle symptom
1) Auto or Manual Transmission?
2) Is the symptom the same w/ the car in neutral and/or w/ clutch pedal depressed?
3) Don67 mentioned vibration in the steering wheel. Is this where everyone is experiencing the sensation of rough idle or is it just a sound (vs vibration) thing to some people?
@Don67 specifically is the feeling from the steering wheel a true vibration (as in it's vibrating in all directions) or is it like the wheel is trying to turn a tiny bit back and forth super fast?
QUOTE (skyblue @ Apr 29 2011, 04:28 PM) index.php?act=findpost&pid=437865
See attached.
I've emailed my local service manager and will try to have this done soon. If it is not the cause, however, something tells me there will be a separate TSB given that several of us seem to be reporting identical symptoms.
Thanks! I was just reading about it on another thread. I will have to call the dealer to see if it I need it done.
I am hoping something comes out of this idle issue. It gets bothersome while sitting in traffic mostly.
Retired Staff
QUOTE (CopaMundial @ Apr 29 2011, 03:45 PM) index.php?act=findpost&pid=437871
Auto trans
Goes away in N or P - simple solution for now drop to N at a light
Vibration is felt in whole car no sound but occasionally you can feel in wheel similar to what you may experience with a bad motor mount
I'm sure this will get resolved soon just one of the minor issues you may run across with a brand new redesigned car and a minor annoyance at best.
QUOTE (someguy @ Apr 29 2011, 05:24 PM) index.php?act=findpost&pid=437886
Auto trans
So one more question would be if you're at a stop, in gear, with foot on brake and the car is shaking... will it stop if you simply let off the brake and start rolling @ idle speed or does it continue to shake until you press on gas to raise the revs? (ypu'll obviously have to test this when no one is behind you waiting to go)
Ok, I lied when I said one more question.
Also if it's shaking and you put the car into Neutral have you noticed if there is a change in the idle engine speed (ie are you at higher or lower RPM when in Neutral vs the shaking symptom)?
One question - what are the RPM's when this is happening? I don't have the problem and mine always idles at about 700 RPM (warmed up) in D.
Retired Staff
CopaMundial good question I think it goes away with foot off brake i usually just drop to N at lights since i read its better for fuel economy anyhow. I dont notice much change in rpm in idle between D or N or with AC on or off.
1 - 20 of 228 Posts
