I recently had a problem with my 2014 hyundai elantra the rpm kept dropping and causing a rough idle, car stalled when gas is applied I got diagnostic scans nothing came up...turned out the problem was my throttle body even though I went to the dealer I was told it was other things...so guys if you experiencing this check ur throttle body and reset you cars idle because after cleaning it the rpm will jump from 1000 to 1500 until idle gets reset.
I don't know your model, but the throttle body can fail, the cheap plastic gears and motor break if you press the accelerator pedal like mad everyday
This is the 2011-16 Elantra, so I'm guessing the model is...Elantra! ;-)
