Hi folks,
I have a 2006 Hyundai Azera with 76k km and I've started having a weird issue about two weeks ago.
When I start the car, it would idle pretty high for a couple minutes and would have a lot of white smoke coming from the exhaust. When I put the car in drive, it sounds like diesel engine, the sounds would increase when I accelerate. When the car is warm, at a full stop and I turn the steering wheel to full lock, it would sometimes kill the engine. I haven't driven it much since the issue started but when I do, it doesn't over heat but does burn oil. I cleaned the throttle body, MAF sensor and checked the PCV valve to see if it is stuck. Has anyone experienced this issue before or know what it might be?
Any guidance would be appreciated.
Thanks!
Thanks!
