I have a Canadian 2016 Hyundai Sonata 2.0T Ultimate. Wanted to confirm what the rotor thickness (minimum) should be for all the rotors. I read this should be on the rotor itself but I did not see it. I found for an older model the following:
Front rotor/Rear rotor - 28 mm/10 mm - standard thickness --- 26.4 mm/8.4 mm - minimum thickness
Is this accurate for my model as well?
Thanks in advance.
you got it! service limits are usually the same all across the board with our cars.
just to organize it a little differently:
front rotors:
standard thickness - 28mm
service limit - 26.4mm
less than a .005mm deviation
.025mm runout
front pads:
standard thickness - 11mm
service limit - 2mm
rear rotors:
standard thickness - 10mm
service limit - 8.4mm
less than a .01mm deviation
.03mm runout
rear pads:
service limit - 2mm
