Does a sunroof on a Santa Fe restrict the range of positions of the front crossbar on roof racks?
On a 2010 Santa Fe with a sun roof, how far forward can the front roof rack crossbar be positioned? A related question is, with the front crossbar in the fore-most position and the back crossbar in the rear-most position, what is the distance between the crossbars?
2007 Honda CRV
Does your sunroof open with the roof going into the cabin or out top to the roof???
The only restriction I see is the stuff you put on the roof rack
But, who knows? I rarely use my sunroof.
Look at the slots on the inboard sides of the roof rack rails. That will indicate how far forward or rearward the transverse rails will go.
MOved mine - on a 2007
But I don't have the sunroof. Needed to pull the slot 'blankers', and the drill a hole way forward for the rack. actually fairly easy. Found the specs somewhere on here ie "search" . MY guess, they didn't want anything to land on the sunroof, and break the glass. Big picture - don't use it that much :) .
