1 - 11 of 11 Posts
Hi, I'm new to the forum. I'm from Orlando, fl.
I need help to find the right size rim/tire and offset.
I have a sonata SE 2011 and drive daily. At first I had no plans to lower the car so probably use more rubber to close the gap between the tire and fender.
All I found was sets with 20" on airbags or coils.
I want a set to fill the space and give a better look for the car. Not sure if I go with 19 or 20.
Thanks!
Eduardo
Here's my Sonata on 19X8.5's +35 offset, lowered with H&R Springs. I was running 225/35/19's in this picture. I run 225/40's now which look better IMO by filling the wheel-well gap even further, and they also offer better ride quality.
Later on when money allows...I do plan to upgrade to 20's though.
All looks good!!!!
But I made my mind to go with 20"s . What size offset that does not rub on the rear and it does look better lowered.
What spring kit is better? K&N?
Discussion Starter · #9 ·
20x9 +38 offset/20x10.5 +45 offset
Matte Silver Machine/Stainless Lip
5x114.3 bolt pattern
245/35/20 front/275/30/20 rear
Fits???
Discussion Starter · #11 ·
Do you know if the wheels from the 2013 new genesis track fits the sonata too cause the rear wheel is a little wider.
1 - 11 of 11 Posts
