Having trouble changing reverse lights
I can't get the bulb out already cut away some of the black foam .
Bump as REUS49 says. I have upgrade mine to LED's and all sockets are twist lock type.
Pull the square plastic connector straight up. Once you pull it off, there will be enough slack in the wires to remove the reverse light.
You already have the mounting nuts removed that hold the light assembly in place. They often stick against their gaskets. Just push or lightly tap it to break it loose. That should make getting to the socket a bit easier. We old geezers with arthritis find our fingers don't bend and grip like they did a while back.
  • Like
Reactions: JoseE
