Hi,
Quick query, I have to replace the small section of brake pipe thats mounted on the rear trailing arm between the 2 hoses for the rear brake, my Trajet's up for MOT in a few weeks and I know it will be failed on that due to corrosion.
I have the pipe and flare tool kit, all I need is the fittings, i had a look on fleabay and there are loads but some are different sizes.
What I am wanting to know is, anyone have any idea what thread size/pitch they are off hand? I'm guessing metric 10x1.00 but I need to be sure so I dont order the wrong ones.
Thanks for all help!
they are metric, but you could always use the old ones if you cut them off the old pipe. unless the heads are damaged they can be used again
