Status
Not open for further replies.
1 - 18 of 18 Posts
Nope.. The ECU will lose some of it's 'learned' parameters, but they will return after driving for a short wile. You'll need to reset the radio channels too.
Note... It's always a good idea to disconnect the negative battery lead first. If you undo the positive lead first, you could accidentally touch the car body with the wrench while it's in contact with the positive post.. That can generate lots of sparks and burn a chunk out of your wrench (Don't ask me how I know this :) ) .
as long as you don't do something stupid like short the battery, short to ground, etc. fuses would likely protect but why risk it?
so generally no....unless you're completely retarded.
I change battery with engine running, then no worry about lost parameters or radio stations... but of course I do this stuff everyday.
What shop do you work at? Please inform us, so that everyone can STAY AWAY.
You sound like a backyard mechanic who has no idea of what he's talking about.
Removing the battery with the car running is one of the worst things you can do. It places the altenator into full field, and can do major damage to ECU's or the altenator itself.
please, josh. enlighten us as to how it causes damage. maybe you can explain the term putting the alternator into 'full field' while you're at it.
please, go ahead and get technical. i'm only a hydro worker.
The altenator and the regulator are designed to sense the battery voltage. If the battery is missing, the altenator goes to "Full field" or maximum output. Its an uncontrolled output from the altenator.
It takes 2 minutes to re-set the radio stations and the clock. Dont be lazy.
Been doing it for 25+/- years.. aint baked 1 yet..
The cars I work on daily use an alternator for supplying vehicle electric when running.. generates AC voltage which is converted to DC voltage via the diode set. ;)
except that's not how generators (or alternators in this case, same thing really) work. as electrical load is put into the alternator, the drag to turn becomes greater. more demand, more torque is needed. you cannot set the thing to go full bore output like that. the drag will be proportional to the electrical load. all AC generators are inherently self regulating like this.
in fact, disconnecting the battery such as sbr is doing is a commonly used simply alternator test. without the battery, you are trying to put the highest load possible on the alternator to see if it can keep up the current.
the only problem i see here is sbr is running a high risk of crossing live cables. that could potentially create a short. my recommendation would be to put some sort of plastic protector over the battery cable terminals to prevent this.
yeah that's the nice thing about science. you don't have to believe it for facts to be true. don't bother looking it up, that would be too easy.
Does this help?
New Car Memory Maintainer w Battery 35808000 | eBay
the only thing I'm worried about with changing my battery is what should I do to have the car "relearn" its air/fuel parameters so as not to run rough or waste gas.
For my old taurus they said to let the car run idle for 4 minutes, but I've read some cars require you to drive it below 40mph for a few minutes, etc.
My fear of changing the battery while the car running is A) the chance of the positive/negative cable causing a short and B) car is running, therefore the fan is also running and so are the drive belts - I wouldn't want to stick my hand in the engine compartment while its running even if I'm working on the opposite side of those.
I agree with Josh here. Why would you want to risk short something out? Why would you want to work with live wire?
Couldnt answer without likely offending somebody, so I myself remove the text.
you're already doing a fine job of that. why don't you post some more memes? that always goes to prove your point.
good on you for being the bigger man sbr.
1 - 18 of 18 Posts
Status
