I bought the correct replacement side mirror for my 2010 Sonata Limited. Also bought the bent screwdriver and wrench needed to do it. A video shows that you just remove the inside triangular side-mirror covering using the screwdriver; next remove the screws holding the mirror; next dissengage the plugs and remove cracked mirror unit; next plug in new mirror and position it; screw it in; replace the triangular covering.
Sounds very simple but I'm reluctant to start it without hearing from someone who has tried it on the exact same vehicle.
Has anyone done this before?
The dealer wanted $250 to replace the mirror. It cost $50 new online (painted, entire assembly); $14 tools.
thanks
liz
thanks
liz
