So just to sum it up. Past few days I had been hearing a grinding/clicking noise from my left front tire. I had an accident on that side a few months back. Went to the mechanic and they said it is most probably the wheel bearing and possible the hub also.
They took it apart and changed the wheel bearing. After two days of getting the wheel bearing changed the noise is back. It is not nearly as loud but it is definitely there.
Any suggestions on what it could be? Could it be the hub itself?
I have a 07 Sonata with 100k+ miles on it
Could also be the CV joint. Those are frequently damaged in quarter-panel accidents.
True, however I did check the CV joint. The boot is intact. Seems to be no grease leakage. Also the noise does not increase on turns left or right.
