Bought some aftermarket HID 8000k bulbs to replace the factory HIDs but can’t find any information on how to replace them. 2018 Santa Fe Sport Ultimate
No offence but to have 8000K then it must be some cheap HID bulbs and even though you like that colour temp the brightness will decrease dramatically from 4300K factory. High end HID bulbs will only run up to 5000K-6000K tops and those will run about $250 usd per set, unless you want looks over function then sure 8000K will suits you fine. In regards to replacing the bulbs, does it have a clip that wraps around both sides? If it is then you must press the clip inward towards the bulb then you should be able to loosen the side one at a time. GL
Stick with 4300-6000° temperatures.
As I often say...Know your local and state regs because if memory serves 8,000 K is very blue. And as Dino pointed out you are going to lose a substantial amount of visibility / output as well as contrast...
  • Like
Reactions: DINO2K
