hey so this might sound od, but i want to remove the spoiler from the car.. is it possible? i plan to remount a different third light in side the car but i want to put a CF civic spoiler instead.. or should i just put the civic one over top of it?
QUOTE (nobodieshero07 @ Jul 4 2010, 03:55 PM) index.php?act=findpost&pid=338803
Is your Accent a hatch or sedan?
If it's a hatch, when you look at the roof, the spoiler is actually its continuity so IMO repacing it with something else won't look good. That said, the spoiler is removed from inside. You remove the trim at the top of the hatch and you can get to the nuts from there. It's similar with the sedan, remove the trunk lid trim (if there's any) and remove the nuts holding the spoiler on. It'd pretty straightforward. The base of the spoiler might be stuck to the trunk/hatch with 2-sided tape to keep water out.
In both cases, be careful not to scratch the paint when removing/installing. If you do, it'll rust.
It's not smooth under the spoiler. The spoiler is needed to complete the body style, so if you were to remove it, it'd be obvious that something's supposed to go there. Only way you're getting a custom spoiler on there is by modifying the current one and going from there.
QUOTE (nobodieshero07 @ Jul 4 2010, 02:55 PM) index.php?act=findpost&pid=338803
You should totally try it. And... if it works I will copy you. Haha.
