I tried in vain to remove the crankshaft pulley bolt and wondered if there are any tricks to removing it?
It isn't left hand thread, right?
Hyundai crank pulleys have separated in the past into two pieces.Can not get this bolt loose on my 2000 Elantra. I have a chain wrench that I'm using to immobilize the pulley and a long socket wrench, but while the pulley isn't moving (I put a chalk mark on it to make sure), the nut is turning slowly and I can see the timing belt moving if I look up through the engine. It's like the nut is turning inside the pulley.
Not good to hear. Any ideas on what i can do?Hyundai crank pulleys have separated in the past into two pieces.
Doesn't it have torque limiter on tightening mode ? Mine (loosening torque 700Nm) has 4 steps, they equal roughly 100/140/180/220Nm. That's what it needs (180-190Nm).Don't use it to put it back on
It's a cheap variable speed, so probably that's how you can control the torque, continuously. However, not very controllable IMO, a slip of the finger and...Doesn't it have torque limiter on tightening mode ? Mine (loosening torque 700Nm) has 4 steps, they equal roughly 100/140/180/220Nm. That's what it needs (180-190Nm).
