preparing for a timing belt replacement on a 2007 elantra. well aware of how to remove the crank pulley and do the job :p
my question is this for you guys: once you have the nut off, does the crank pulley come off by hand or is a puller required? came off nicely wiggling it by hand on any accent i've done, but never done this particular job with the elantra.
thanks.
yes it does come off by hand (in extreme cases you my need to use a couple of screwdrivers as levers)
Remove bolt, grab pulley with hands and wiggle it off (98.2% of time)
If not, spritz some PB BLaster at fitting and keyway, tap hub hammer and try to wiggle off (1.8% of time)
