How do you go about removing the door sills, the ones on the interior, I need to pull them to run some wires. In my last car I cracked them removing them because I pulled the wrong wall.
I am talking about the runs along the edges of the carpet, I need to run my amp wires, plus need to gain access under the carpet to get some wires under the seats for floor lighting.
The front ones just pop out. The rear ones have screws under the rear seat and then they will pop out too. Somehow, I managed to crack one of my rear ones when I installed my stereo, but if you firmly, but slowly pull starting from one end and working your way over you should be fine. I think I started getting a little to anxious and worked too fast on the one side in the rear of the car.
Great, thanks for the info! I have a bass knob I am debating installing in the little pocket next to the hand brake as nothing will fit in that pocket, plus it will be out of the way and not very noticeable. I just need to get the wire in there somehow haha..
