I have a 2010 Hyundai tuscon and just recently changed the rear wiper blade.The problem im having is that the wiper does not touch evenly across the entire wiper,It sticks up on the outer part of the blade i used a 14 inch like the book at tge parts store said.What could be the problem?Thanks.
You've purchased the wrong size blade. The original Hyundai blade is 300mm long. That's approx 12", not 14.
448633
Oh ok,I just went by what the book said at the parts store but i could have looked at it wrong.Thanks for the info its greatly appreciated.
So I got the 12 inch blade and its the same thing as the 14 inch.It is raised up from window about half way across the wiper,its seems like the blade isnt fitting properly into the connector for some reason.
Sorry, I can't help you with that from 3000 miles away.
