Rear windscreen washer has stopped working - and instead started squiring water on front windscreen when operated!!!
Anyone know the fix for this before I start meddling...?
QUOTE (stupet11 @ Dec 7 2010, 05:46 PM) index.php?act=findpost&pid=377645
Take it to you dealer and have it replaced under warranty. The 2 way valve is seized..
A quick fix would be to swap the two water pipes at the pump so at least the water will clean the windscreen. Its located on the bottom of the washer bottle on the OSF
QUOTE (Master_Tech @ Dec 7 2010, 05:35 PM) index.php?act=findpost&pid=377722
Hope it is seized - if it's blocked, they are gonna charge me £78 to unblock it! Time for big bro and is AA van to visit me!
Water pump is hard to get to, as are pipes, and if there is a block somewhere in the pipe, I won't know (until I get a bill!). I wouldn't mind paying £20-£30...but £78 is a bit much.
UPDATE: rear washer has started working again off it's own accord!
I'd avoid taking to a dealer unless you are 100% sure it is the motor that has seized, and therefore fixable under warranty, as otherwise you could get stung for a bill to unblock a pipe.
I reckon mine had ice somewhere in the pipe - is all I can think it was. Possibly a motor malfunction - will wait till and see ehat happens...
QUOTE (stupet11 @ Dec 9 2010, 09:59 AM) index.php?act=findpost&pid=378189
With the temperatures we have been having, the concentration of pre-mixed defroster is not high enough, it needs almost 100% concentrate.
