i was wondering if the following is normal ?
if i hit the "rear window defroster", i get all sorts of interference on fm radio stations. i dont ever listen to am, so dont know if there is a problem, or not.
i recall reading that my antenna is buried in the rear window glass.
i figured that might be what is causing the interference, if both things are imbedded in the glass ?
Litle box at rear to integrate antenna and defrost (diversity antenna) is likely taking a dump..
QUOTE (sbr711 @ May 23 2010, 08:48 PM) index.php?act=findpost&pid=325586
you will need to remove the trim panel behind the right hand rear door (above the rear parcel shelf) to gain access to the box.......this trim panel is held in by clips and it just pulls off, but it is a tight fit[attachment=18257:0190005A.jpg]
