1 - 12 of 12 Posts
Wheel bearing started to heat-up to the point I could smell the tire or sealant! No wobble or noise and spins well...I ordered one from Amazon. :crying:
At least, from what I have read, the rear is easier to replace than the front :)
Are you sure the heat is coming from the bearing?
Yes! :evil: I only wish it was the brakes!
I don't know what rear hubs are for your car. For my Accent they're ~$130. After what I went through with the fronts, if I have to do the rears, I'm just buying the whole assy! :eek:
Remember the goodle days, when you took the wheel off, removed the dust cap, and fished the bearings out? ;)
I have an IR thermometer that's great for pinpointing heat sources. Maybe have your mechanic check when you drive in. If you are a customer he should do it for free. Takes less than a minute and I don't know any mechanic that don't have the tool.
Discussion Starter #10
Sorry I didn't follow-up...it wasn't a fun job doing it on the ground without a proper lift. The brakes are not as bad as they said, getting the link out-of-the-way is pretty easy. Possibly, when the brakes were done previously...they reversed the bolt so you didn't have to drive it passed the shock.
The sucky thing is the 4 bolts for the bearing go through the back and they're recessed into the casting. This car is also from the "rust belt" so that didn't help either. :wallbash:
Discussion Starter #12
Are the pads wearing evenly? common prob up here, is rear pads sticking in calipers due to rust .
You are correct, fairly new pads and the inside one was uneven! :evil:
1 - 12 of 12 Posts
