My 2011 rear passenger side seems to sink down during cold days and nights when parked a certain amount of time any suggestions?
Seems to could be the key. A bad front strut would stay low all the time, bad rear shock would make probably make car rock a lot after going over bumps.
Sometimes pavement is sloped and it can create a weird perception.
Could measure with a tape measure from the ground to top of wheel well on both sides of car; should be within approx quarter inch.
You will find a few threads on here that talk about suspension airbag leaks. Yours is probably a small leak. When using the car, the suspension air compressor keeps the height up. When you park for a while, the air slowly leaks out and the compressor is not on to keep the pressure up, so the car will sink as the air bag loses air.
If it is an air leak, it will get worse.
I mentioned on another post that I had the exact same problem with my 94k 2011 Equus. I bought replacement rear air bags off ebay for $385 delivered and spent $140 to have my indy install them. Problem solved.
