Hi all. New member here. Just changed out my rear stabilizer links to attempt to resolve a clunky rear end. The new Moog links went in successfully but now it seems noisier than before. Is it possible that the new links are putting more stress on the sway bar bushings?
Look at the Rear Lateral Arms. Looks like a ball joint on one end, and you can see if it's loose by rocking the wheel from side to sides / up and down. Had to replace both on my car to cure the knocking noise.
Agree with MarioT.
If End Links are tight and Sway bar bushings are good, then do investigate the Lateral Link bar. Had a mysterious rattle / thumping over bumps for 6.5 years and long story short, it was a worn out Lateral Link Support bar. Even though it manually tested good multiple times. Replaced with "Dorman 522-006 Lateral Link" from Amazon and my vehicle's mysterious sound is now 100% gone.
Hope this helps.
