No, those are aftermarket sensors. Cobra parkmaster to be exact (notice the little dimple at the 12 o'clock position). The sounder is quite a common failure item on those kits.
You can check that the sensors themselves are working by putting the car into reverse with the ignition switched on, then go to the back of the car and lightly rub a finger back and forth across the face of each sensor. You should be able to feel the sensors pulse against your finger. Or you can use a screwdriver as a stethoscope and listen for them clicking. If all the sensors are pulsing/clicking it's probably the sounder that has failed.
440721
Thanks for the info just have tryed to feel the pulsing but carnt feel.it going to try screw driver trick
But i have no idea where the module is
The module will just be tucked in behind one of the boot trims. If you have a look up behind the rear bumper you might be able to see where the sensor wires enter the car. That will at least let you know what side of the car the module is on.
