you will need to remove the door trim and then remove the main window by removing the rear window runner, once the runner is removed from the door you will be able to remove the quarter light glass with its rubber moulding, this can be a tricky job if you have never done it before and if you are not confident it may well be better to get it done at your local repair shop
Thanks the trim is a bit of a problem with removing the winder handle, seen the topic about the clip but can't get into to remove it, so will probably have to get it fitted will give it another go. Thanks again.
