Could anyone tell me the capacity of the rear diff on AWD santa CM 2.2 CRDI with 5 speed manual?
Ive just drained it and it says to refill to the bottom of the fill hole. Im having problems seeing the fill hole propely. so it would be nice to have a ball park number I could just squirt in and then go carefully for the last 100ml.
thanks in advance.
I have found that the stated capacity is seldom accurate. This is the surest method. Put a catchcan under the rear diff, fill the diff until it starts to drain out. Stop filling and let it drain out the fill hole until it stops draining. Level is now at bottom of fill plug.Install plug. Clean off differential, dispose of used oil.
yes it is fine, check this out
