Have 2009 Hyundai Vera Cruz. Replaced both rear blender door actuators. Still doesn't work. Any suggestions
I would try a reset. Pull the fuse for the system and replace after 1 minute. With key still off turn the controls to full cold and max fan speed. Turn the key to run position (lights in cluster on...NO start). Do not touch anything. The controller should go through a relearn. Takes a minute. See if that does the trick.
