I thank you sir. ?That looks really smart, I always appreciate it when someone tires to stick to the factory standards for wiring looms etc, makes for a much more durable modification. The extra running lights are a nice touch.
do you have pictures of this?I also added a front lip (06-07 Impreza WRX STI S204 Front Bumper Lip Pu Urethane) which you can get from Amazon for about 50 bucks.
The only trimming you have to do is cut off the ends as they're too long.
It's very easy to install and easily workable to bend to the shape of the bumper and it looks amazing.
See the pics for details.
Here's some pics.do you have pictures of this?I also added a front lip (06-07 Impreza WRX STI S204 Front Bumper Lip Pu Urethane) which you can get from Amazon for about 50 bucks.
I've been reading up on the 60mm TB from the elantra and stumbled across people saying the elantra gt airbox was larger and bolted in? Any word on that? Can't seem to find any concrete write ups.ms and discs work well for track days which is the purpose of this build.
A brand new 60mm throttle body from a 2013 Elantra is waiting to be installed and I'll do a how to on this. While I'm changing the throttle body I'll be doing a throttle body bypass and will have a how to on that as well.
I hadn't decided if I'm going to knife edge the throttle plate yet and may also flush up the plate screws too. I'll have to see everything when I get home to make that decision.
I did this on my Z24 drag car and Paseo and worked well for its purpose.
In the mean time here's a couple of pics of some recent work.
I'm running the AEM cold air on the car and I will see how the larger flange on the 60mm will accept the AEM intake adaptor.I've been reading up on the 60mm TB from the elantra and stumbled across people saying the elantra gt airbox was larger and bolted in? Any word on that? Can't seem to find any concrete write ups.
I know my K&N drop in helped with low rpm & higher load hesitation so I'd imagine a larger surface area would do some good - especially if paired with a larger TB.
My concern starts to be intake velocity at that point. It's only a N/A 1.6L and not exactly completely starved for air.
made some discoveries about the RB Accent and 3rd gen Kia Rio .
looks like this applies to the /2018- Rio/Accents as well. Many parts seem the same as seen in photos from under the hood of 2019 Accent sedan
Tuned for that wheel install, picking myself up a Nardi soon and i'm gonna use the same adapter.Finally got some parts in and I'll be installing these while I'm home.
Brand new ($69) 2013 Elantra 60mm throttle body. I'll do a how to on this if I don't mess it up. ?
New NRG wheel, hub, and gen 2 quick release for the car. Removable wheel is a must when installing gauges and have to get under the dash to run wires. Plus it looks good too. ?
I'll try to do a how to on this as well.
Stay tuned. ?
Hopefully I'll be doing that tomorrow and again do a how to on it.Tuned for that wheel install, picking myself up a Nardi soon and i'm gonna use the same adapter.
I'll be pulling the axle probably Sunday.I hope that rear drum to disc conversion goes right for you. As a GS owner I was interested in trying that myself, but some other posters were of the opinion that the ABS computer will never accept or work with the new disc brakes. If you try it and it goes well please let us know how to do it - thanks!
