1 - 8 of 8 Posts
My 2008 i10 (80k miles) is rattling a bit from the suspension (front and back). It sounds to me like worn bushes. Is this a known problem ? I took it to my garage but they said there wasn't a problem. It may not be serious, but there's certainly something going on. Is this what has been posted already as "anti roll bar bushes and drop links" ?
Thanks
You could take it to another garage but cars do get more rattly as they wear. If you trust your garage I wouldn't worry. If there is a major problem it will be picked up on the MOT.
Thanks Longshot - naturally I don't want to pay out for unnecessary work. We have another can of the same vintage (Citroen, 2008) - no rattly sounds at all.
Thanks
Worn bushes? You must have the outback edition...>:D
Pretty vague description of the 'rattle'. Could be anything. Is it a new rattle? How long you owned it?
00000732
* Do a search for your problem. A lot of stuff has been asked and answered.
Thanks,
Welcome aboard.
I've owned the car from new.
With the benefit of nearly 50 years of driving and owning cars, no - it could not be just "anything".
It's a rattle in sync as you go over bumps.
My question really is - does the i10 have any known problems such as this as it gets older - at 10 years, it is really at the end of its design life.
Based on the information you have given I suggest you learn to live with it or replace all bushes. Of coarse you may be able to find that one bush that is causing all the rattles and remove it from the chassis. >:D
Just laugh at it. Helps me.
Discussion Starter #7
Thanks to those who replied.
I just had the MOT done and the rattles were from the front suspension drop links - which have been replaced now.
No more annoying rattles !
1 - 8 of 8 Posts
