I have had a rattle that lasts 2 seconds on my 2012 Elantra for the since about 2 oil changes ago. The car has 152,000 miles on it and I've changed the oil regularly per the maintenance schedule, although not always with a Hyundai filter.
I'm strongly suspecting that this is the timing chain tensioner, but I could be wrong. Other than this, the car runs fine. I tried having the oil changed by the Hyundai dealer with the OEM oil filter and the problem appears to be a little worse. It first started to appear on cold start up after the car sat for >8 hrs or so. Now, it appears on cold start up >2 hrs. I noticed that the dealer put 5W20 in it. I'm wondering if lower viscosity oil makes the problem worse during hot weather. It seems when the weather is colder it takes longer for it to appear. I'm wondering what my options are here. I really don't know how much $$ it is to go after the tensioner and how critical it is - the dealer said they do replace them and that doesn't always fix the problem though I'm not sure what he meant. I have read a few other posts about tensioners here, but I'm also wondering if this is an issue with the new engine.
Any thoughts are appreciated!
