What do you think this sound is?
Been trying to track down this issue since I got this car a few months ago. Replaced oil, spark plugs, air filter, fuel filter, cleaned MAF and TB. Engine is tuned up.
Replaced belt tensioner and its fixed most of the belt rattle but there's still a bit of noise coming from there.
The engine vibrates a lot when stopped in gear, but is smooth in park. Purchased new front and rear engine mounts, will install soon. There is a 3rd rubber transmission mount and a hydraulic engine mount which are also suspect.
First clip shows when the accessory belt tensioner was rattling and making a racket. Then some clips showing the worn engine mounts. running the engine without the accessory belt. Last clip show the starting off knock from outside the car, accessory belt on.
