I believe I had a rat chew through a wire to the connector to my neutral switch. I can't crimp the cable due to length. Wondering where this cable is fed from and how to find the harness to replace the cable . Anyone with any recommendations as to how to repair this I really appreciate.
Automotive tire Motor vehicle Gas Automotive wheel system Auto part
Automotive tire Motor vehicle Bumper Electrical wiring Automotive exterior
You can remove the pin from most any connector. If you cannot remove the pin solder a piece of wire, it might look like crap but should work.
i agree with medium. soldering is your most cost effective and time efficient solution. i guess you could repin it too but you will still need a splice or solder then down the harness.
2017 Sonata Sport 2.0T
Ive used
and
or go to a junk / wrecking yard and take one off a wreck, just cut the wiring with enough slack to reconnect and solder/shrink wrap
