Hi everyone....I've had a new problem surface with my car and I wanted to see what everyone thought, or if anyone had had a similar problem. Car is a 2007 2.4L Sonata w/ 62k (2nd owner = out of warranty). HID kit installed w/o issues about a year ago. Has harness with fuse integrated hooked up to battery. No issues at all in the past year.
Last week I was driving on the highway and I went to turn my headlights and bam, my car bucked a bit. I was on the phone so I thought maybe the road was uneven and I didn't see it. So I turned them off a bit later (and then back on) and bam, now the car stalls. I was concerned about the lights having blown the harness or harness fuse, and killing my ECU. The car started back up with no issues. I didn't turn on the lights and went back home so I could investigate. I checked all the wires/fuse/harness and found no visible issues. Furthermore, the lights now turned on without any problems/sparks/mushroom clouds. I set the headlight switch to auto and drove the car around the rest of the week with no bucking/stalling issues.
Randomly last night I go to flash my high beams at a car and bam, the car stalls! So now I don't know if it is an HID issue or something else. When the high beams turn on the HIDs stay on (so there is no re-ignition when switching back to LOs). This makes me think maybe it's something else within the lighting sytem/electric system.
Any thoughts? Battery? Alternator? Thank you all (in advance) for your wisdom and help.
Update: Switched out the old bulky ballasts for new slim/digital ones and the problems SEEMS to be gone.
