The Monsoon radio in my 2005 SF has begun acting up. Sometimes the radio or CD will be playing and the display is blank. Other times you cannot change channels or switch from radio to CD. Often all is well. It appears that turing it off for several minutes will correct the problem, however on a few occasions when starting the vehicle the display is blank. Has anyone shared this experiance or have any suggestions?
Discussion Starter · #2 ·
I actually found an option and tried it today. With most stereos and radios if you unplug the unit and hold in the power key and then plug it in again the system will reset to factory settings. On this radio I found that you either remove the radio fuse or disconnect a battery terminal for a minute or so to reset it. This will also work for stuck Cd's, etc. I'll report on results.
It has been a week since I pulled the radio fuse for a few minutes to allow the system to reset. Have had no issues since. Appears to be a solid way to deal with radio and CD problems.
