1 - 9 of 9 Posts
Hi everyone, I'm thinking about buying a Hyundai Equus Ultimate 2011 to 2013 model.
Questions:
a) What's the difference between the 2011, 2012 and 2013 model? Is there a year that's better than others in terms of quality of materials and reliability?
b) How reliable is the car? What are the things that tend to break down and how much do they cost? Also, is there a way to prevent said break down?
Finally, if there is anything that I should be aware of before this purchase, please let me know.
Thank you to all in advance. Truly is appreciated.
Equus 2011-13...before model refresh...look at this forum and you will see someone with "livery"(limo use) with minimal problems. Most chassis problems are with air suspension-worn/punctured air struts-failed pump, or the Dreaded VSM off error(brake switch easy, adaptive Cruise radar module expensive). Ultimate has multiple interior luxury items which may fail...
My wife's 2011 Standard Equus had the memory buttons for drivers seat replaced, the power seat motor/track assembly as well, and the rear reclining seat motor assembly replaced, and a few operator errors (coin in cigarette lighter pop fuse after a carwash). Annoying trim issues (exterior b and c pillar trim very hazy, non-polish able- buy add on trim or vinyl wrap), common headlight clouding at the top 1/5th, car super prone to door dings from others(Panel thickness). Tires get used up fairly quickly(20-25K max on Hankook Ventus v12 evo2).
Glaring obvious omissions-Side collision avoidance detectors in exterior mirrors, oil change warning in display, 6 way only seat on passenger front....things you expect from a similar vintage luxo sedan of equivalent cost and trim.
IMO...2014-16 the better choice if in your price range...11-13 superb value but costly to repair if you dont DIY or have trustworthy mechanic.
Differences, quoted info from Edmonds.com:
"For 2012, the Hyundai Equus gets a new 5.0-liter V8 engine and an eight-speed automatic transmission. Power rear side-window shades now come standard on the Ultimate."
The 4.8L in the 2011 has the advantage of being designed to run on regular gas, the 5.0 suggests use of higher octane. But as many have said, the 5.0 runs fine on regular, you just will not get top horse-power. Either gets "enough" power. I rarely need to push the accelerator very far unless I am just playing around. (5.0L=429 hp, 4.8L=385 hp; 2011 has a 6-speed transmission)
"The Hyundai Equus is unchanged for 2013."
$40-50,0000 Hyundai,,, buy LEXUS
sbr: So is carbon an issue with GDI Equus 2012-16? You repair these type of cars, yes?
And yes, LEXUS makes great cars, which you pay for in high resale value...guessing most rational folks lease these depreciation monsters...(I bought used) and maintain them as they can afford(super expensive electronics)...My choice in 2015 was a 2011 Equus with 46K, or a 2009 ES 350 with 75K for the same price...the Equus was 40% less than a same model year LS460, the comparable model.
Don’t buy any Equus. I have a 2014; engine failed with only 32k mikes and Hyundai refused to warranty the issue and I had to pay $15k out of pocket to replace. I own 2 other Hyundai’s and will NEVER buy another under any circumstances. Hyundai is not a reputable company.
Questions:
Thank you to all in advance. Truly is appreciated.[/QUOTE]
I didn't see your photos...your description (and an internet search-Ohio/Georgia/Florida Car dealer) made me think accident damage incorrectly repaired (and hidden from Car fax, et al) or some flood damage. I almost forgot the slight lifting the dash leather has around the defroster vent...I live in the west(dry climate), and look for decent eBay parts for plastic things like headlamp/tail lamp that burn up in the sun....An Acura/Lexus it is not...stealer-ship issues are yet something else. I bought a 3 year comprehensive warranty from a Hyundai dealer, to cover the electronics/chassis components...
The adaptive cruise control (on the 2011 anyway) is not very smart, and has issues when being overtaken by other cars, especially when in center lane with truck on right and faster car in left lane....I don't notice this...I'm usually the one in the left lane ;)...you can turn the adaptive function off...and this tendency was described here...
1 - 9 of 9 Posts
