My Flex Pipe is shot again. This is the 2nd one to go bad within a few years. Yet, as I recall the original Flex exhaust pipe lasted far longer.
Before I go ahead and have one installed I'm wondering what are the differences in quality ? Should I request a certain type/material/company over whatever they would have just used.
I just find it hard to understand why the original lasted for so long, while the replacements went much faster.
Thanks....
When the flex pipe started leaking on my 1988 Accord at 180K miles I had the choice of OEM for over $500 or aftermarket for half that.
I went with aftermarket since I didn't plan to keep it much longer. DIY replacement.
I sold the car to a friend at 220K miles and 21 y.o.
At 260K miles the aftermarket pipe failed.
My friend took in stride. After all, things are going to break on a $500 car.
They are all stainless. There is differences on how the flexible tubing inside the braid is made and if there's inner braid or not. That can be a simple corrugated pipe or a so called 'interlock' type tubing.
The interlock type is the most robust/expensive.
see here
Discussion Starter #5 (Edited)
Was it stainless steel?
OEM or aftermarket?
Car and year would be helpful.
Grand, yes I believe it was aftermarket SS.
I have a '05 Sonata.
see here
As they are all SS, and from your comments it seems it comes down to build quality. The shop I went to apparently is using cheaper quality parts.
Is this a correct assessment ? If so, I'll have to request better quality flex pipe when I bring it in. Or possibly just do it myself and be assured of what I'm using.
My flex pipe failed in my '02 Sonata V6 at about 115K. I had been stuck on some ice and rocking the car to get out. Since it was Feb in Upstate NY, I would up taking it to an exhaust shop and paying about $700 to get it replaced. About 18 months later, the replacement started to fail. I took it back, no warranty and they said they might be able to weld in a new flex part for about $200; otherwise it might be up to $1200 because of CARB regulations.
Anyhow, what I realized it that it seems likely that my flex pipe is failing because there is too much slop in my motor mounts. I would suggest you check your motor mounts for excessive play.
