2013 Sonata SE
a friend of mine has another pair of the stock 18s sitting in her garage and will sell them to me. i'm gonna put hers on my car b/c they have newer tires and put my current wheels on the wife's 07 tiburon.
my few questions are
1) both bolt patterns are the same 5x114 - i'm not sure if there is a difference in offset?
2) both cars have TPMS sensors on the wheels, does anything need to be changed/added/removed when putting the sonata wheels on tibby?
these are the wheels i'll be putting on her car:
Not sure if it is any help, but I took 17'' wheels off a Tib and used them for my winter set up for my 2011 turbo. Only issue I had was a very slight rubbing in the back using 225/55/17. Tire rubbed on the wheel well @ rear about half way up the inside. I trimmed 1/4'' and fixed it.
I don't know everything about tires, but the sonata has 225/45/18 and a 225/55/17 rubbed slightly when mounted on a Tib rim. So maybe the off set on the Tib rim is slightly less...so in your situation, the sonata rim might stick out slightly depending on the depth of the Tib wheel well.
