I am not sure if the technology package radio has RCA connections and a remote wire connection for the amp or not. You can buy after market products like a LC2 or a PAC SOEM-T (Which is what I used in my 2013 GLS Sonata). Basically what it is is a Line converter that converts the signal for one of your door speakers into a device that will allow the connection of an amp. Depending on how much you are wanting to spend and what you are wanting to get out of it they can be cheap to EXPENSIVE.. I have the PAS SOEM-T 2 channel converter and paid somewhere around $20 on Ebay. You wont get as much tuning for the sub (on the converter side not the amp side) out of that one as you would an LC2 or similar line converter. That type of converter can get expensive but you can add a sub to your Azera
