1 - 20 of 119 Posts
SENIOR MODERATOR
So I was thinking that the NF is starting to get some age on her and starting a thread specifically for the some of the problems we have had with our Sonata's would be a good idea. Nothing to in-depth. Something we can sticky as a quick reference. When posting list the following:
Year, Engine and model. (2006, 3.3, GLS)
Mileage at Which Problem Started
Problem/Issue
Fix
Approximate $$ Cost
Notes
Link to thread (if any)
SENIOR MODERATOR
Discussion Starter #2 (Edited)
07 I4 GLS
Approx 52K
Only problems I've had were the sun visors. Replaced the passenger side a couple weeks ago (out of warranty), looks like the driver side may need to be replaced as well.
All other repairs have been wheel/tire related (Pittsburgh potholes)
06 V6 GLS
Approx 125k
Driver's side sunvisor; ~$90, easy fix
Brake light switch; dealer fixed, $0
Ignition switch; $can't remember, semi-easy fix
Year, Engine and model - 2009 V6 Limited
Mileage at Which Problem Started -
20k?
Problem/Issue -
Oil leak onto alternator.
Fix -
Dealer fixed under warranty. They replaced the valve gasket and cleaned the alternator.
Approximate $$ Cost -
Free under warranty
Year, Engine and model. (2007, 2.4, GLS)
Mileage at Which Problem Started: 90K
Problem/Issue: Creaking noise
Fix: Dealer replaced upper control arms for worn bushings.
Approximate $$ Cost: $425
Notes: Bushings can be changed out without replacing the control arms.
Year, Engine and model: (2006, 3.3, LX)
25K
Problem/Issue:
1) Timing Chain Tensioner2) Sun Visor
Fix:
Dealer fixed at no cost.
1. Free 2) ebay: 70 bucks each
Notes:
Changing struts and springs is DIY if you have a friend and a spring compressor - if you strip a stud, be ready to cut a lil slit off the brake dust shield, unless you want to pry off the entire hub and replace bearings.
SENIOR MODERATOR
Discussion Starter #12
2006, 3.3, LX
85,000
Pin hole rust thru on brake line (Maryland, not rust belt)
Took to non-dealer mechanic, spliced new OEM line in
$89 part and $220 labor
The dealer wanted about $1000 to try and make a new line, $700 to splce new section. I walked over to their parts counter and ordered a new front line for $89. Was going to replace myself but too difficult w/o a lift. I was told to replace a full length lines you need to raise engine (to get lines to master cyl) and also drop fuel tank for rear. Just have it spliced if possible.
2006, 3.3, LX
Approx 65,000
Check engine light/Trans slipping
Repaired (replaced trans) under 100k warranty
$0
Light came on while on a trip. Dealer in Ohio read codes and told me to take it in to servicing dealer when I returned home. The dealer I bought it from said they did not see any codes, so I had the other dealer call them. Be persistent!
Approx 72,000
No cranking, had electrical
Replace starter, then battery
I think about $650 at dealer
I've had this happen on both this vehicle and to a greater extent (other issues) on an 04 Santa Fe 3.5l. Starter locks up when it goes bad/burns out, and battery needs replaced at the same time. Not sure if older/weak battery caused the failure or it just was time to replace when the starter failed.
Year, Engine and model. (2009, 2.4L, GL)
Approx 100 000km
No cranking, had electrical ,starter was running but not engaging.
Replace starter ( went to scrapyard , got 2009 Rondo starter motor.
About $240 part+ $150 Labour at dealer ( did job myself for $90 total cost for part + my time, 1hr)
Year, Engine, Model: 2010 2.4 GLS
Milage: 38K
Problem: Onboard computer experiencing voltage drop causing car to shut off shortly after startup
Fix: Under warranty so dealer fixed it (Thank god bc it is $2000 for a computer)
Cost: $0 for me bc of warranty About $2000 if not
Problem 1:
Year, Engine, Model: 2007, 3.3, Limited
Milage: 51K (approx)
Problem: clicking sound from engine, took it in to have it checked. Harmonic Balancer was bad? had to be replaced.
Fix: Replaced Harmonic Balancer
Cost: No Charge
Video: Here
Problem 2: (same car)
Mileage: 42K
Problem: CEL light, unknown issue, car ran normal, turned out to be a bad throttle position sensor.
Fix: Replaced TPS sensor
Cost: No Charge
Problem 3: (same car)
Mileage: 56-current (63)
Problem: Torque converter constantly locks and unlocks between 45 and 30
Fix: N/A
Cost: N/A
Video: Here
Pro
Problem 4: (same car)
Mileage: 5K
Problem: Kocking sound from behind dash
Fix: Replaced blend door actuator
Cost: No Charge
Problem 5: (same car)
Mileage: Unknown / misplaced documentation
Problem: Crack in vinyl dashboard
Fix: Repalced entire dashboard
Cost: No Charge
I probably have had the Sonata in an estimate 6 times for airbag light, at
one point a belt buckle caused CEL light to trip, so they had to replace it.
Problem 6: (same car)
Mileage: 26K
Problem: black detail strip around side windows was peeling off
Fix: Dealer completely redid detail striping
Cost: No Charge
My dealership hates me! :eek:
Year, Engine and model - 2009 2.4L GLS
Mileage at Which Problem Started - 40k
Problem/Issue - Left side trunk shock
Fix - Broke last night (6/15/12) Nothing yet.
Approximate $$ Cost - Wondering if its under warranty, haven't had the chance to call yet. And if not if it would be cheaper to DIY or pay to get it done. (AKA~wondering if any speical tool needed would make it cheaper to get done by a pro or buying the right tools)
__________________
__________________
Free if you are under the 5yr/60k bumper to bumper warranty. :D
1 - 20 of 119 Posts
