i'm still in the process of removing my transmission but cant seem to get the starter off. i know its a 14mm bolt but they just wont come out.....the top bolt i am using a socket and the bottom i am using a wrench. i cant fit a bar in there also. anybody have some advice........................ its a 2000 elantra
It's (2) bolts with 14mm heads... socket on the top with extensions works, and long closed box end wrench on the other down there in the tight spot... wear a glove so you don't bust hand open when bolt suddenly breaks loose.
