My display light is not working however, my indicator lights still work, but the light that illuminate the panel in the night for you to see the speed, temperature, fuel, rpm is off now i can't see how fast i'm going at night since it doesn't light up. I checked all the fuses and none of them were blown. What could be the problem?
The dimmer switch is not responding I changed it but it is also not responding as well.
I'm having a similar issue, service adviser at local dealership says possibly dimmer switch. Dash lights will all work if the headlights are off, once headlights are on, some of the dash lights will turn off. I have not replaced the dimer switch yet, D-cruz, did you find a solution?
