Two primary issues that has caused with my car is transmission,and "check engine" light.The transmission sometimes shift harshly between gears while in automatic mode,I've taken the car in three times for this issue,and have been told this is only the computer code problem.The transmission computer is ceared, reprogrammed,and the transmission runs smoothly again.The "check engine" light(CEL) has been more insidious.About ten months ago the light started coming on,i took the car to dealership .No cause of light was ever detected.Since than i have taken the car three more dealership in two countries and the
problem has not been still rectified.
Hi and I wish your problem will be solved soon...
to my knowledge.....
the Hyundai dealers have in their workshop a computer named Hi Scan Pro...
This computer will solve most of the problems in hyundai cars and it is official from the Factory.
so if the dealers that serviced your car do not have Hi Scan Pro, then I think you will not correct your problem.
I wish that we could buy this scanner,,but I think it is so costy..
Wish you the best.
MMK
