Problem At Hyundai Accent 2001 - Automatic Transmission
10K views 92 replies 6 participants last post by  Joker_Card
Hello. I have a Hyundai Accent, 2001 with 640,000 km (stayed with our family due to an emotional connection). Two months ago I changed gear oil (full replacement) + filter.
When I lowered the carter, there were some pieces of iron caught in the magnets.
Two weeks ago I did a 200km ride and after 100km a light bulb came on.
After I got home, I scanned and came up with 2 codes:
p1529
p0734
When the lamp was lit, a 'knock' was killed in the vehicle.
Also, fuel consumption increased (was a liter to 13 km, now a liter to 10 km) and in addition
I have noise when I press the gas pedal (when I do not press the noise disappears), attached is a video:
(In the garage, they offered to dismantle the dashboard at a cost of $ 600, without committing that they would solve the problem. A catalytic converter was replaced two months ago to renew, so the noise is not related to the converter either.)
I reset faults two weeks ago, and since then they have not returned, but the question is what to do.
See less See more
#3 ·
Those two codes are as follows:
P1529: TCM MIL On Request Signal. This basically means the Transmission Control Module is telling the ECM (Engine Control Module) to turn the MIL (Malfunction Indicator Lamp) on.
P0734: Fourth Gear Incorrect Ratio
Judging by the amount of large pieces of debris in the second picture there is some mechanical damage inside the transmission causing your problem.
#7 ·
What is a needle bearing? What did the guy fix in this link?
If not, I would love a slightly more detailed explanation. Should the chalk bearing be completely disassembled and sent for renovation or is it possible to do it at home? I ask because I have some knowledge and that I have been taking care of my car at home for the last few years ..
Right now all the gears are working. But there is a 'knock' when the vehicle shifts gears, especially since the vehicle is still cold. In addition, fuel consumption has risen. And the shift between third and fourth gear happens at 3200 rpm, which seems to me quite high compared to the other gears.
#9 ·
Sorry, been busy with projects, just saw your post. He replaced the OD (4th gear) front needle bearing, thrust washer, and thrust plate. They sit between the front of the end clutch retainer assy and the o/p (rear) end of the planet carrier assy. You say all 4 gears are working on yours, yet one of your needle bearings has failed. When the car is idling at a stop (in D) and you come off the brake and press the gas pedal, does the knock occur then (accelerating up to 6-10 MPH)? As you continue accelerating, does the knock occur going into 2nd? As you continue accelerating, does the knock occur going into 3rd? As you continuing accelerating, does the knock occur going into 4th? When you decel from 4th, does the knock occur going into 3rd? And, does the knock occur decel'ing into 1st (from 3rd)?
#15 ·
I'm trying to figure out what the problem is with the gearbox in my car (in light of the findings I found while replacing the gear and filter (pieces of iron). I was told it was a needle bearing, and I was trying to figure out if what the guy in the video is doing is replacing this bearing, Do to fix the problem in my gearbox.
#14 ·
I do not know what the ideal situation is in gear shifting. By and large, I do feel the gears shifting. Is this not right? By and large, it seems to me that when the engine is 'cold' the 2 gears come in less well and 'hit' is felt. But when the engine is 'hot', the gears come in better. Especially 1-2-3, I think the fourth did not go in well.
As for your questions, I shot a video, but I speak Hebrew. Do you understand anything from the video? If not, I will try to shoot an English video this week.
#16 ·
Based on what I've seen and read on a few forums now if you found tiny cylindrical pieces of metal in the pan then it's likely this bearing. all I can tell you is in the video he has code P0734 which is 4th gear incorrect ratio.
In the video he shows the metal in the pan and the destroyed bearing.
He's removing the end cover to get to the end clutch and where that bearing is.
He purchases a bearing kit from the USA but you could just get the individual parts. I see there appears to be a bush or sleeve in this kit. i don't see him fit it.
I don't know what more is wrong with your transmission but if it had done 640000Km then it has lasted very well indeed. At some point it needs a rebuild and seals inside go hard and you could have other pressure issues causing harsh shifts.
You could try this repair and see how it is.
454083
Similar transmisson here:
#20 ·
If you could answer each of the questions in posts 6 & 9, those answers should help refine the location(s). There are multiple needle bearings at play in multiple gears, and it's important to rule in or rule out creep (post 9) before zoning in on the end clutch's needle bearing.
Can you post an english video? (I don't see a video here, nor your pics.)
To replace it, is it necessary to remove the gearbox from the vehicle?
This will depend on the location(s). If the kickdown bearing (or band or drum) is involved, yes. If carrier bearing, yes. If end clutch/OD (front and/or rear), then no.
Plus, there likely are multiple issues.
Referring to Gerard's pics, Hyun changed the needle bearing design, going from closed to open. That's when the issues ensued.
#21 ·
Sorry for the late response. I'm on probation at university.
As for the video, there are 4 parts in the renovation kit, but in the video you do not see where the first part on the right is composed (such a cylinder ..):
Regarding the questions in the transmission. It depends on whether the vehicle is hot or cold. When the vehicle is cold, there is a knock in the shift of all gears.
When the vehicle is hot, there is a knock in the transition from first gear to second, and third to fourth. It seems to me..
And yes, there is a knock even when the vehicle shifts from third gear to first gear.
As for the video, I can not upload a video here.
#22 ·
The bushing fits inside the OD (4th gear) shaft - in between the 2 oil feed holes.
The end clutch retainer is rotating in all gears, when the car is moving. It would be misaligned, if its front needle bearing failed.
1st to 2nd involves the release of the planet carrier and the activation of the rear clutch and kickdown, events that involve their bearings and depend on the end clutch bearing.
3rd to 4th involves the end clutch and kickdown, again involving those bearings.
3rd to 1st involves the end clutch and clutching of the planet carrier, followed by the kickdown.
Thus, it appears the kickdown and/or end clutch needle bearings have failed, and there likely are wear issues on the kickdown band and drum and 4th gear shaft splines.
#23 ·
Thanks for the quick response. So what do you advise me to do?
Does the kit I bought (according to the YouTube video) have it to solve the problem in my car and there is no need to disassemble the gear from the car, but just open it from the side. Or I will just keep driving until the gearbox finally dies and only then replace it The gearbox itself.
By the way, if you get into a state of general overhaul of the gearbox, and disassemble the vehicle, how do I know which parts to replace?
And another question, at your disposal .. Do you think a new speed sensor can be useful for shifting gears, or has nothing to do with the problem?
#25 ·
You are in a difficult predicament. The trans has high mileage, the kit only will address part of the issue, the other parts, at least here in the USA, are hard to find and may not be available, and a proper overhaul requires tools you won't have (such as for ensuring correct bearing/shaft/gear preloads/spacers). The question is: will the trans work good enough if just the kit is installed (and done correctly - there are several critical steps involved). I don't want to discourage you from tackling it nor discourage you from keeping the car given the personal connection, but I would estimate/expect a 40-60% likelihood of success. Your options are to (a) follow @12GLS3.5 's advice in post 5, (b) try to find a Hyun reman trans with a new torque converter and replace your trans cooler hoses (and clamps) and flush the cooler's channels (in the bottom of the radiator, using Hyun's flush product) before filling the new trans, (c) try to find a good used low-mileage trans and torque converter and replace your cooler hoses and flush the channels before filling the used trans, and/or (d) take the time to research the availability of the overhaul parts - new bearings throughout the trans, new clutches and discs and wave and return springs (correct quantities of each), probably new clutch retainers for their pistons, new kickdown parts (band/drum/rod/rod retainer/piston/sleeve and probably switch), new o-rings/D-rings/seals/gaskets/filters (these come in their own Hyun kit and generally are available), new solenoids, new (or useable) OD gear shaft, and output shaft locknut. Option (d) will be instructive because it will reveal what is and what isn't available. If you get a good used OD gear shaft, heads-up: Hyun had 3 different lengths. Yours must match.
The input shaft speed sensor (pulse generator "A") likely is not among your main issues. It is, however, reporting - or trying to report - the signals from the misaligned end clutch retainer. I would recommend it be tested (by backprobing BOTH of it pins and connecting the leads to an o'scope) before deciding to replace it. Its signal will increase in amplitude and frequency as the input shaft increases speed, and its signal should be quiescent when the car is at a stop. If option (a) is pursued, ask the trans specialist to remove and clean the pickup ends of each shaft speed sensor, while the overhaul work is being performed [or if options (c) or (d) are pursued, do that during those also]. The shaft speed sensors come (already installed) with Hyun's remans, so these steps aren't necessary for option (b).
If you decide to tackle the kit job only, get the new (or correct-length useable used) OD gear shaft ahead of time. Also, go s l o w l y when you remove the left cover (or double end cover - Hyun had two configurations there), so you don't dislocate the OD parts behind the left cover before you can see them. Some will want to fall out/down. You will need to know their orientations for reassembly. Also, you will need - want - new o-rings for the bottom of the left cover. There are small holes there c r i t i c a l for oil routing to the OD retainer - for 4th gear. Also, be sure these holes are NOT blocked by any cover sealant, when s l o w l y reinstalling the left (or double end) cover. Also, be sure to use the proper fluid at the end when refilling the trans, and do not over- or under-fill. Finally, bear in mind, the end cover bearing (which you will see when the cover is removed) and all the internals of the end clutch retainer and the end clutch hub (which slides out easily) will be worn. Now would be the time to replace all of these, IF the kickdown parts are holding in there.
#26 ·
Hi, thanks for the explaination, I have a few follow up questions.
The knock occurs when accelerating going into first and third.
You mentioned replacing the trans cooler hoses. I'm curious how those are connected? (maybe I am misunderstanding what the trans cooler hose is?)
I think I will go the route of the KIT job. What is the OD gear shaft?
Also, included in the KIT is a metal ring that wasnt in the video and I'm wondering what that is.
#28 · (Edited)
Oh. I was confused in writing. I wrote that the knock is in first and third gear, and I really meant to write that the knock is in second and fourth gear.
Regarding the 42220LK Kit, I ordered it from the website:
Believes he will come to me in the next week or two and then I will be free to do the work.
I asked about the radiator cooling pipes, because I did not understand why replace them .. they look fine .. do you think that replacing them in addition to all the 'renovation' is needed? why?
You wrote: "and done correctly - there are several critical steps involved"
So I consult, where can I go wrong?
And another question, at your disposal. Should I do the treatment using the kit (option D), I must empty the transmission fluid and disassemble the carter, or can the chalk be opened on the left side even without emptying the fluid and there is no fear that the fluid will spill out ..
#29 ·
2nd and 4th involve the (full) kickdown.
See post #25, final paragraph.
The fluid will gush out. Everything behind the cover is awash/sitting in trans oil. So, yes, you will want to drain the AT oil pan; then remove the pan and main filter (there are several); re-check the pan, filter, temp sensor and bracket (they are right there and could have contaminants on them), and inside the bottom of the VB (lower chamber) (once the main filter is removed) - for sherds and material and sludge, get them all clean, (and then do the kit job, removing the double end cover or left end cover, depending on which Hyun config your trans has).
On the hoses and cooler flush-out, (at least one of your) needle bearings failed inside the mechanicals of the trans. We don't know where all the sherds ended up/got mechanically and hydraulically shoved to/are.
#32 ·
I ask about the kicks there are at the entrance to second gear and at the entrance to fourth gear. If I understood you correctly, the kit I ordered is not related to them and therefore will not solve it?
In other words, to solve if these kicks, is it necessary to replace additional components? If so, what are they? And can I replace you in order to replace them by opening the side gearbox?
As for the cleaning, well, I need to open the carter. So on the way I will already replace the filter, but it is impossible to disassemble more things from below? Like the valves and solenoids and clean them? You said to look there with a flashlight .. but Ann will think of a way to clean in case I find waste there, just wondering how to clean ...
I also tried to upload a video, but to no avail. Then I will upload it to YouTube and send a link.
Aside from the knocks, I also wanted you to hear the buzzing when you press the gas in second and third gears ... which is something that has been around for half a year now.
And for that I uploaded a video on YouTube ...
#33 ·
Regarding this and the video, the evidence is consistent with post #22, paragraphs 2/3/4/6.
BEFORE doing any disassembly of the VB (a much more intricate undertaking), see what the state of the end clutch front bearing, front thrust, OD gear shaft splines - both ends, OD gear shaft internal bushing, end clutch hub splines, end clutch retainer assy, and end clutch rear bearing are. Pictures of these will determine next steps.
#35 ·
One of these is the shaft; the shaft rides - or was riding - on the (rear needle) bearing.
Eye Automotive tire Silver Cylinder Household hardware
Simulating what yours probably looks like. Shaft, missing bearing, missing thrust, hub, retainer.
Wheel Tire Automotive tire Locking hubs Alloy wheel
Let us know the shaft's length and whether the retainer has 16 concentric springs or 8 clutch (fingers) springs.
And, post (all) the pics.
