Hello,
2006 Azera Limited. Powered passenger seat has two switches. Move whole seat forward/back, and recline forward/back. All working except the move whole seat back. Seat moves forward and now does not move back.
I hear reports about the switches going bad, so I pulled the cover off the switch and pulled the switch off. I do not know which pins to jump to test if it's the switch or another issue.
I also look up ordering a new switch, and for my make/model it's showing me a vastly different item(has 3 positions for memory).
Any help here would be greatly appreciated. Can post photos if needed tomorrow when it is light out.
Discussion Starter · #2 ·
This is the switch RockAuto and MANY other sites are showing me match, not even close:
from RockAuto: /en/catalog/hyundai,2006,azera,3.8l+v6,1433291,electrical-switch+&+relay,power+seat+switch,4612
Incorrect item for me. Also had to goof with the URL since I am new...
This looks a LOT more like it, again I goofed with the URL sorry if this is prohibited...
From FourGreen /store/scripts/SWITCH-ASSEMBLY-POWER-SEAT-RIGHT-SIDE-p-882953L100K7
Pulled the switch apart from its housing, down to the circuit board. On here is printed:
DMT(TG-CAR)
FR PWR SEAT S/W(LHD 4WAY)
Hello,
Check both slide motor switch(with connector S20) and slide motor limit switch(with connector S28).
Hey thanks for the reply. Last night I had to pick up a friend and was a little impatient, so I pulled the switch apart down to the circuit board and actual switches... Lo and behold it worked when connected. So it was the switch/switch housing having an issue.
