1 - 1 of 1 Posts
(1) Seems the front passenger door of my 2014 Azera Limited will not lock using the interior power lock buttons, the exterior door handle buttons, or remotely via key fob. However, all seem to unlock door as designed.
(2) At the same time, welcome lighting is intermittent when using the key fob. I usually keep my headlamps and fog lamps on if parking at night or in a garage, so I can easily pick out my vehicle; however, they do not always light up when I use the fob to unlock the car. Similarly, hazards do not always respond when locking the car.
Since the lights and other locks all work fine otherwise, it's obvious the fuses are good and the batteries are all charged. I suppose the passenger door lock actuator could be bad, but would that also contribute to the lighting issue? Or is this just two gripes coincidentally at the same time?
1 - 1 of 1 Posts
