Ordered a pollen filter for a 2007 1.4l Getz. However the manual mentions TWO filters. So what now?
Discussion Starter #2
Surely someone has changed the pollen/cabin filter?
Hoping to get this sorted before SWMBO comes back from her holidays. The screen was misting up badly ,even with the heater on, unless the aircon was blasting away.
[I confess to sometimes driving a Getz but I did own this handsome SIII untill recently:whistling:]
There are two filters in the parcel received so the mystery is solved.
Existing filters very mucky and black at 3 1/2 yo and 16,000 miles. Air Recirculation control cable and a wiring loom need to be moved out of the way then a little tab lifted to enable filter access cover to be removed. Was puzzling which way round to insert new filters, but then realised they will not fit the wrong way due to male and female grooves in the housing and filters. Struggled to get the filter cover back in place until I realised the hinge area for the glove box needs to be pulled out a bit to give clearance. Not an easy job to do the first time but could do it in 5 mins now! :banana:
