Put a error reader on the car today after my wife said that the car did not seem to be running right. It showed a PO335 error (which is the crank position sensor). Where is the this sensor located? Schematics or a actual picture would be great.
Vehicle is: 2004 Santa Fe, 2wd, 2.7L V6
Thanks,
Chuck
QUOTE (jsinton @ Jun 13 2010, 07:25 PM) index.php?act=findpost&pid=332693
It's a two minute job to replace.
Not unless the end of the sensor stays in the block... tech beside me went and pulled 1 out Fri, left the bottom of the sensor stuck in the block, some 17-19mm down in the hole... he was mad..
Here is better pic of CKP location... NOTE : starter is removed in this picture --
