Hi all, I took my 2011 Santa Fe, 3.5 liter, in for the tail light water thing, and a cracked fitting down near the thermostat (all warranty). I bought a rad flush while they were in there.
I picked up the car, drove for 1/2 hour and got a CEL. Plugged in my code reader and got three PO198's, oil temperature sensor. The dealer was closed by then, so I left it in their lot and will call them tomorrow. Their repair performance to date has been poor, and that's being polite. Any ideas how a rad flush could cause a PO198? Could they have forgot to plug the sensor in? Is it located anywhere near the thermostat housing? Did they not get the air out of the rad, and maybe the engine did get hot?
-Chris
According to reference material, the oil temp sensor is buried under the throttle body, not readily accessable from what I can see.. likely a fluke it turn up, though I dont think we seen that DTC yet
Thank you sbr711. I just heard from service, and they said it was just that the sensor connector was not plugged in all the way. Apparently they had to disconnect it to get at the broken hose nipple. Problem solved, I hope.
-Chris
